1carwash1
I'm rebuilding a pumping plant and remembered in another post that the regulator bypass should be plumbed on the same side of the pump head. In the picture shown, it shows the inlet on the left and the bypass return on the right. Is this wrong?
Also, I was considering replacing all the regulators with either the BR5-2 or SMC 555 series. If I went with SMC, would it be better to use brass or stainless?
What is the difference between the 5551790 and 5551390 or should I just opt for the brass 5550090. I have always used the BR5-2 and was leaning in that direction. The regulator that came with the plant is a VRP200; it doesn't seem to be readily available. Any ideas?
Running 3HP motors & Cat 5CP2120W pumps.
