cleaning up mud
What do you feel is a good replacement for the cat 310 pumps? that's cheaper but works just as well? And the 5cp.
General Pump is cheaper and works as well, but they're higher maintenance. More than likely whatever problem you're having with the Cat pumps will be worse with General.
Why are you trying to get away from Cat?
I replaced a couple of my Cat 310's with Armitsu 313 pumps. So far, no problems and they run quieter.
