In my tunnel, I currently have a fresh water rinse between my ccp/drying agent and before the blower. How are you guys setting this up - are you blowing off the ccp directly, or rinsing it first?
In my IBA, the cycle is set to apply a sfr after the ccp, but since it is a sfr, that is where it has to be, and anything left on the car will dry "spot free" anyway. My tunnel, however, has no sfr, so should I be rinsing the ccp or not?
I ask because it seems as though the fresh water rinse after applying the product inhibits the drying somewhat, perhaps because it is bringing the ph up a bit. The downside to not using a fresh water rinse after the ccp, however, is the fact that any of the little droplets left appear white and spotty (mainly on the glass) - a charactaristic I have found with most products of this type. I have dialed in the concentrations to pretty much the absolute minimum I can use to get a break and have also tried several products. I do not have towel drying at this location, so I would like to improve this - without putting in a sfr system.
I'd appreciate your thougths on this.
Thanks.
Thanks.
