RO issue: not making enuf RO water
My GinSan water lovers 600hpd isn't producing RO water. Got back from 10 day vacation to find ice maker shut down (cause we use our RO water)& RO System not producing RO water. Plenty of reject water being made. Ha. I can pinch reject hose & force water through the membrane & get good flow, but of course that isn't good RO water.
Electric motor running good, & Procon pump is 1 yr old. Could problem be membrane is failed, & restricting the flow? Has just a trickle of good RO water being made...
You can call or text if that's easier.
409)200-4667 (hoop)
Coach Bowles
Dan Kamsikas helped me fix it.
1st thing he said check, drain solenoid, was the culprit. That little prick was stuck open!
