washtubman
I want to use my RO reject water for HP rinse on my automatic. Will the following setup work:
Reject water is stored in 250 gallon tank with a submersible sump pump at the bottom. A 1-1/2" hose will go from the sump pump to the automatic rinse tank. A float switch in the auto tank will be wired into the sump cord and adjusted to turn on the sump pump before the city water float valve kicks in.
Comments appreciated.
