RO system pressure
We stock membranes spec'ed at 80 psi, 100 psi, 150 psi, and 225 psi.
Realize that these are the test pressures used by the manufacturer. These pressures, along with 77F feedwater (and some other factors) are what allow the manufacturer to claim the output gpd of the membrane. In other words, the manufacturer is saying: If you provide this membrane with X psi pressure, 77F feedwater, (and some other lesser requirements), you can expect X gpd production (typically plus of minus about 15%). Nothing says the factory spec pressures are "ideal." If you run a membrane at pressures above the factory spec, you can expect faster permeate ("RO water") production, and slightly better rejection (i.e., RO water that is slightly more pure).
So check the specs of the specific membrane(s) you have installed - that will give you a starting point. If you don't have any records of which membranes (brand and model) are installed, you can always pull one out and look at the sticker/label on the body of the membrane.
Most commercial RO systems allow you to adjust the pump output pressure. To do this your system should be equipped with a pressure gauge that shows the pump output pressure. You'll see that if you have a needle valve to adjust the concentrate ("brine" or "waste water") flow, as you reduce concentrate flow the pumped pressure will increase. However it is generally not a good approach to adjust concentrate flow to try to hit a target pressure. Rather, use that needle valve to hit a target concentrate flow, and let the pressure fall where it may. Remember that based on membrane diameter you'll have a minimum recommended concentrate flow (typically 1 gpm for 2.5" diameter membranes, and 3 gpm for 4" diameter membranes). If you have proper pretreatment of the RO system feedwater, you'll typically be safe shooting for that minimum concentrate flow. A lot here depends upon how your RO system is plumbed - so check the manual for your specific system. You'll also have either a globe valve on the output of the pump, or an adjustment screw on the side of smaller pumps - both can be adjusted to change the pump output pressure.
Russ
Every RO is different. As Buckeye said, the system pressure will go up if you turn your concentrate flow down (and your permeate will go up), but also your water quality will go down. Adjusting an RO is a skill that is learned by many years of experience. There are often 2 needle valves or globe valves, 2-3 pressure gauges, and 2-3 rotameters (flow meters). Each individual RO is set to maximum output or maximum water quality production using a combination of data from each of these 7-9 items. Influent water temperature is the other item, as Buckeye mentioned.
