RO unit has mind of its own
dogwasher
Im having a hard time adjusting pressures on my RO unit. It doesn't want to adjust well. The manual is written by a idiot:rolleyes:
From what I understand my process water should be spread 2 GPM from the reject water(according to the directions) and my pressure out @ 225-250. When I adjust the valves I just cant dial in without one of the other guages going wacky.
my ro units run as follows not sure if it works across the board
to make a gallon youll lose a gallon.
so if your making 5 youl be rejecting 4 or 5.
my systems all have two membrane setups
so im making 5 loosing 2.5 on each membranes reject
incoming tap pressure 60 psi
pump psi 150
membrane 1 111psi membrane 2 120psi
hope that helps a little
