RO water for chemicals
APW
South
Will a touch free clean batter using RO water to mix the chemicals? At one of my locations I use soft water for the chemicals but not RO water. At my other location I use RO water to apply the chemicals and I swear it cleans better, or maybe it's just in my head?
water guy
Which brand of soap are you using? Im using AP Formulators and thought about it also.
Jeff_L
That’s an expensive way to clean in my opinion. Wonder if there’s a more cost efficient way, such as dwell time adjustment.
APW
South
I use a "private label" chemical right now, but I am fixing to try Quest chemicals as soon as they come in. I have two passes of Hi and then a 15 second dwell time at the end. After a wash you can wipe your hand down the car and it will wipe clean where you wipe your hand and blackish film elsewhere. When it wipes off so easy, you would think there would be a chemical that would get it off.
jfmoran
PA
Excerpt from an article on Professional Car washing, there appears to be no benefit to using RO in the wash cycle and it may even be a detriment:
"Since RO water reduces surface tension beyond that of softened water, it has nothing but negative value when used with polishes, sealers, clear coats, hot waxes or drying agents. There are some misconceptions that drying agents can be added to the RO rinse. Why would we remove 3-400 PPM (parts per million) of mineral solids from water to make it RO pure and then put 2,000 PPM of wax solids back into it?
Some might consider using RO water for the entire wash process. From a presoak and detergent standpoint, there is no positive benefit to using RO water in place of soft water.
First, the soluble sodium salts left in the water after softening have no detrimental effect on cleaning. Also, RO water can reduce the foam level of friction foam detergents and touchless presoaks.
The RO water apparently interferes with the bubble formation dynamics causing the bubble wall to thin out faster because of intense surface tension reduction that breaks the wall formation of the bubble.
If softened water has no known value in the high pressure rinse cycle, then neither does RO water. Considering the water volume, the cost is very high and unnecessary. Leaving a residue free rinse water surface has no positive value for subsequent wax cycles."
