Rowe changers and others
Bubbles Galore
Michigan
I have a BC-1400 that I think someone is trying to string. I know that there are not any changers out there that are 100% string proof, but don't they have some things in place to help prevent it from happening? Has anyone come up with their own solution to help combat this? I appreciate any help.
No I don't have cameras, and yes I know I should. :eek:
Converting it to a Mars will not only remove the most troublesome and expensive to repair components, but will stop stringing.
$999, EtowahValleyEquip.com.
Rowe has a conversion as well, but it costs more and I don't think it replaces the CCC.
Fatboy769
Living the American Dream
Irmo, SC
Are they actually stringing it or are you finding pieces of a bill or something else hung in the validator? I have (2) BC-200 changers that use the same validator as the 1400 that have been in service for 8 yrs and have never been strung. I keep a record of the counter in both changers, and they have always matched up with the bills in the stacker.
The Rowe/Mars conversion kit is $740.00 from Rowe.
That's good to know, but I would think it's worth the extra money to eliminate more hardware.
Whale of a Wash
5 Washes 36Bays 2Vectors
Fargo,ND
I am not a fan of the original rowe validator , but i think it has to stack the bill, before it pays out. The few times someone tried it, i earned $10 both times. I am up to 4 rowe to Mars conversions now am am really happy with them. The etowah also replaces the very heavy duty rowe power supply, and pulls out the escrow buckets so it pays out in real time, like a slot machine. Count your money every day and let us know if you really are being strung.
Bubbles Galore
Michigan
I just ordered a coin counter so I can keep much more accurate records of what is going on. I like etowah valleys system due to the fact that I can elimenate as much of the Rowe hardware as possible. I will let you guys know what I find.
washme1
clive, iowa
One thing you can do. The BC-1400 can be programmed to shut down automatically if your predetermined number of any bill denomination is inserted within a predetemined amount of time. For example, my changers will shut down for 15 minutes if someone attempts to change more than two $20 bills within 5 minutes. I give more leeway for
$10s and $5s accordingly. This way, if someone successfully strings one $20, it will shut down when they attempt to string the second and will likely go somewhere else the next time. You set all the parameters to your own situation. There are instructions in the manual or you can call Rowe
Whale of a Wash
Fargo,ND
To count our quarters we use a Salter 610 coin scale. About $300 and no moving parts. most of my scales are 10yrs old. we leave them on all the time for better accuracy, and no failures yet. The coin counters i had were always having problems
I like coin scales too, but our bank charges a pretty large fee if the bags are off, so we have to use a mechanical counter. For just confirming what goes into the changer, a scale is definitely the way to go.
Bubbles Galore
Michigan
I have always wondered if scales were that accurate. I guess this post answers that question.
Fatboy769
Irmo, SC
Just exactly what do you get in the Etowah Valley kit that you don't get with the factory Rowe kit?
Can anybody answer this question? If I'm going to basicaly spend $250 + more for the Etowah kit, I'd like to know what I'm getting for the extra money. Besides the validator, I've not had any problems with my Rowe changers.
You're one of the lucky ones. I've heard much more bad than good about Rowe.
Bubbles Galore
Michigan
is the active payout better than the bucket method? I would be worried that one of the motors would stay running and pay out an exponential amount of coins.
The escrow buckets are the one thing I like about Rowe over Hamilton, not just because of the security against hopper run-on but for the speed of vend for $5 and $10 bills, but it should be a minimal issue if the EV kit is made properly. Like Hamilton, it should shut down the hopper if the coin sensor doesn't detect a drop within a predetermined time. It would be a good question for Jim at Etowah Valley.
Or did I understand the basis of your question correctly?
Bubbles Galore
Michigan
Would that screw up my ability to dispense a mix of dollar coins and quarters? I am definitely over having to screw around with these BA-50's.
