Why would you want to?Can you put an injector on the output side of a high pressure pump?
I am trying to visualize your setup. Where do you use the 125 psi regulator and injector? On the inlet side of the pump feeding it with city water pressure?You have to use a pressure regulator a long with an injector. We use a Generant regulator https://www.kleen-ritecorp.com/p-32...2-pressure-regulator-hc-series-5-125-psi.aspx and a DEMA 204C injector https://www.kleen-ritecorp.com/p-16...ries-water-flow-adjusted-with-orfices-12.aspx We’ve used this set up for well over 30 years with very few problems.
The regulator goes ahead of the injector to lower the incoming city water pressure. You have to lower the incoming water pressure so the pump will draw chemical. It's pretty much the same as using a zero-pressure regulator, but the Generant regulator and DEMA 204C will last longer. I've never had a head wash out using this system.I am trying to visualize your setup. Where do you use the 125 psi regulator and injector? On the inlet side of the pump feeding it with city water pressure?
Because that's how I interpreted Chad's original question of where to put it, on the input or output side of the pump.Why would you want to?
Chad, that’s good to hear. Your pumps will last a lot longer with the regulator/injector setup. The pumps don’t have to work as hard to draw chemical. I’ve never had a head wash out and the seals last a lot longer, years longer. We've never had very good luck with the zero-pressure regulators.Thanks Randy and everybody for the input. I set up one bay with regulator and injector. Works great and will probably slowly convert the rest of my bays over.
