Self serve logics
Julius852
Hello,
Someone could shourtly describe how works self service wash stationmostly I am interestics in the automatics logics.
Thank you in advance.
Timer receives coin pulses, enables output to switch which energizes relays and solenoids.
Julius852
I need more wide description for example when you push the foam button in the box 1 the HP pump starts then activates reject water solenoid, foam dozator, air solenoid for foam generator and etc. I need some think like that :)
traveler17
SE NC
What’s a foam dozator?
