Where do I input the variables of my wash at?
Looking at the top left of the Spreadsheet, there are 6 columns, Date, Bays, Vacs, Vending, Pop Bottles, and Pop Cans...(I have two pop machines and keep the income separated for comparisons)...If you want, you can change the pop columns with something else you have. FYI you can't delete columns or rows since the calculations are dependent on row and column location. Moving on, rows 3-11 are for January input, 12-20 is February, etc. If you collect weekly, just use the empty boxes down each column. Any box that has zero's or #DIV/0! calculates from the input boxes, so nothing is ever input in those boxes. If you click on one of these boxes, the calculation is output in the bar above the spreadsheet so you can see where and how and what its calculating. All totals for each month is output on the right side under each perspective month. If you input water usage in the "Gallons of Water" column, it calculates how many gallons you've used per dollar taken in the bays. This can be useful in determining when to change
nozzles or if someone has discovered how to cheat your bay meters! Its incredible how close this calculation is weekly. It also lets you know how much more weep costs in the winter and can help you adjust price based on fact.
Moving down the spreadsheet, yearly totals are calculated for each column from left to right.
The next set of calculations is Bays and Vacs LED7
Coin count, current week and last week. You start by putting
coin count in for the 4 bays "Last Week" column and same for vacs if you have LED7's. The second week you put new
coin count in the current week column...The yellow output box subtracts last week from current week and the orange box converts to dollars. The output dollars should coincide with how much you took in for the week or collecting period both bays and vacs. For the 3rd and future inputs, you have to move current week numbers to last week and input new current week readings. Again I use this to validate bay income with meter readings to make sure thugs have not outsmarted me!
Dropping on down, manually input the year, bay total income, and Total for the CW. The output is what the % of bay income is to total income and then % Total is comparison from year to year. To the right is Percentages of income, everything here is calculated from other inputs. Nothing to do here but read the output.
Then bottom right, input Utilities and NG and everything else is calculated for you. Bay and Vac Totals, Clear from Bays and vacs, and what the percentage is - Profit v/s Utility costs. I didn't include mortgage, but could easily be added.
Hopefully this helps explain things a bit. Sorry for the long post, but lots going on in this spreadsheet. Questions?
