Serious timing issues, need help
DoingMyBest
A few days ago our Tunnelwatch PC needed replaced, after the instal and data transfer wash would function but timing is seriosly off and 3 functions arent working.
The setup:
This site runs DRB, Bellinger conveyor, and we run normally on simulated pulse.
The timing issues get worse the farther in the tunnel you go. Wheel blasters domt follow the wheel but they do come on. Rinses towards the emd of the tunnel come on way early amd end early, blowers are doing the dame. Im fairly new in the indusrty and i havent come arcross this before.
Things that ive looked at:
*Changed chain speed (to get semi close to a decent wash)
*New tire switch installed 2 weeks ago and i can see its working in TCS
*TCS all fuses are good, Relay card seems to be working fine
*Functions are turned on in Tunnelwatch amd it appears that all data transfered correctly.
Ill take any suggestions.
