Shampoo and fragrance mounting
Detbjr
I picked up a used fragrancer and a shampooer. They are just boxes with no stand. I wanted to mount them either to some Coleman supervac3 or on a pedestal. Question is 1) which would be recommended, 2) where could I get suitable pedestals or do I have to fabricate?
mounting near or on the vacs would be beneficial because I can use same card readers and timers.
Fragramatics has a nice stainless bracket for mounting them on the side of a vacuum.
I have mounted to the side of Super Vac 3 on the side opposite the door. I just drilled Holes thru the Vac and bolted the Machin to the Vacuum. Used Large Washers inside the Vac. Had these for decades. I ran a separate power line to these. So I used the unit's coin mech / timer. Ithink issue would be that cost per time is usually higher for these than the Vacuum.
