GreenTreeCarWash
I have six feet of vending space. There currently is a glass front/rear load vending machine that needs to be replaced. I am thinking of removing the glass front and filling in the hole.
Then replacing the glass front with Laurel Electronic Vending Units:
1-Laurel 3 Column #899
1-Laurel (Little Trees) 5 Column units #599
2-Laurel 1 Column #399
http://www.laurelmetal.com/electronic899.php
These Laurel units will take up about the same amount of space as the broken glass front. My goal is to simplify and avoid down-time. FYI: The 6 feet of space has direct sunlight and this direct sunlight has led to the glass front needing repair/replacement.
Total Cost for these Laurel Units: $3700+/-
Good Idea or Bad Idea? Thank you for comments.
