Buzzie8
What does everybody or anybody think about this pump for pumping pits?
http://www.northerntool.com/shop/tools/product_7913_7913
Tell me more about this Cat Pump. What powers it? Did you put this together yourself or did come as a unit?I've seen someone use something like it. You have to agitate the mud into a slurry so the pump can move it. I've used the venturi-type pump Cat makes - it's only around $150 and has no moving parts to get damaged or worn.
Uh, you pump it into a trailer and haul it to a dump site legal in your locale?I like this idea but what happens after you pump it 15-20 ft away from the pit? Then what? Does the water/dirt/slush vaporize?
So you haul away 4 Cubic feet of dirt that is now 100 cubic feet because you just added ten times the water to it...sounds like a dumb idea.Uh, you pump it into a trailer and haul it to a dump site legal in your locale?
What do you usually do with the sludge from your pits? Does it normally vaporize?
Yeah, they were saying that it is moved at 10:1. I think you need help with your math. 4 Cubic feet of dirt moved at a 10:1 ratio is 4.4 cubic feet you after you add water, not 100 cubic feet.So you haul away 4 Cubic feet of dirt that is now 100 cubic feet because you just added ten times the water to it...sounds like a dumb idea.
Guess you cant take a joke vapor boy
Here’s a few I found. The one I had was metal.
http://www.ultimatewasher.com/sludge-pumps.htm
http://www.pressurewasherproducts.com/SLUDGE_PUMP.html
http://www.pressure-washer-parts.co...cat=Sludge+Pump&L2=Accessories&L3=Sludge+Pump
http://www.northerntool.com/shop/tools/product_200327889_200327889
http://www.pressurewasherstuff.com/index.php/cPath,291_295
