Soap to each pump is gravity/vacuum fed through 1/8" poly lines connected to a 1/2" PVC pipe back to the mixing tank. Sometimes it takes about a minute for soap to get to the bay even though I'm getting flow (14-16oz a minute through the Dwyer flow meter) indicating the mixture is diluted in the 1/2" pvc pipe/manifold back to the tank. Once soap gets to the bay, show is normal. I can then go to any other bay and get soap to the bay in about 10 seconds which is normal. It seems this issue happens only when the wash has had no activity in awhile, all bays dry. Maybe when soap isn't selected in awhile? I have no way of knowing that. No matter which bay I try first (After all bays sit awhile) I get the same results.
When switching each bay to rinse, I see no soap in the rinse water indicating all the soap solenoids are seating. My soap tank doesn't seem to be diluting either...It never runs over and the show in each bay is always the same once soap reaches the bay.
Any Ideas as to what could be causing this? I just noticed this happening and don 't know what could be causing it. I don't have check valves on any of the 1/8" poly lines. BTW, I have weep guns so when the system goes into bypass when the trigger gun is released, there shouldn't be any positive pressure on the soap lines, so I'm stumped.
