Two years ago when I was trying to figure out which direction to go, Randy took the time to explain his system to me and send me tons of pictures. I went as far as ordering a Dema Injector and pressure regulator to test. It worked exactly as Randy described….But…I just couldn’t bring myself to rely on either the hot or cold solenoid to open to feed my pumps.
With 35 years in Manufacturing and Engineering, I try to build “Fail-Safe” systems whenever possible. That’s why I decided to go the Erie valve and float tank route…. For those that don’t know, The Erie valve is a motorized valve that is either normally open or normally closed depending on which way you feed the hot/cold supply. A Heavy spring returns the valve to closed position when de-energized. I opted to have the hot feed come in on the normally open side for
soap and wax (Not energized). Most customers select
soap first, so the Erie is in the correct feed position for hot
soap…No delay…When rinse is selected, the solenoid is energized and switches to cold water. Switch over takes about 8-9 seconds. Hardly noticeable to the customer and no negative affect.
Every time I wash a bay out, I am basically testing the solenoids. The water starts out warm on rinse and quickly changes to cold water. If it fails to turn cold (Which has never happened in 2 years!) I will know the valve has failed. Worst case with a failed valve, customer gets 100% hot water for all cycles. Not a bad thing. Another upside, it’s physically impossible for a non-working Erie valve to starve a pump. The “Fail-Safe” part I designed into my system. But then I have float valves! Pick your poison!
