Some bay FB Freezing Some Not
washregal
Pennsylvania
I have a problem at a wash - (7) SS bays.
bays 1- 4 FB is not working - seems ot be frozen - bays 5,6,7 FB works great no problems.
1-4 are on one side of my equipment room.. 5,6, 7 are on the other.. Anyone have this before?
Suggestions?
I’ve had the same thing happen years ago. I increased the amount of water that I was weeping and it solved the problem. Someday I need to measure the amount of water I’m weeping, I know it’s a lot.
washregal
Pennsylvania
System Set Up
My change over system is tied into my Dixmore on output 2 - The Methanol soap comes on at 34 deg. and purges at 33 deg. I did just increase the purge to about 1.5 min. Before had them at 30 sec.
I am running a black tip through a 511 hydrominder.
mjc3333
PA
Dixmor weep mizer FB meth mixtures
I had the same problem with the same type setup. If the purge is not long enough, some bays will not get enough meth. mixture thus will freeze. Manually turn on the output #2 to set the purge in motion. Then go out any physically check all of the foam brushes to see if they are all purging. Whatever bay / bays are purging first will most likely not freeze, the bay or bays that are last to recieve the purge will be at risk of freezing. I have my 8 bays purge for 2 min at 29 deg. I found that the foam brushes do not freeze right at 32 deg. Most cust. in my area do not use the brushes below 25 deg. Most use them in the winter when it is above 30 deg. This has saved me money on the meth. solution, as most FB usage is on the reg. mixture, not the meth mixture.
Suggestions?
More info needed:
Are you
Weeping
Purging
Using winter formula FB Soap
Have trough heat
