Sonny’s 25hp central vac motor
Jason@Eco
How long do the bearing’s last on a 25hp central vacuum motor? They are only a couple years old and I’m hearing a growling noise from one of them. I’m hoping someone can tell me if that’s a bearing or something more serious?
Keno
Are they greaseable bearings? If so, are they maintained with the proper amount of grease? More isn't always better. If sealed bearings and running constantly for a couple years, could see them start to make noise. Either way getting bearings changed before a failure is way cheaper than buying a new 25hp motor
NewEnglandTech79
It could be the bearings on their way out. Or the noise you're hearing could be one of the turbine blades has broken away from the turbine shaft internally.
