Spot free rinse pressure to bays ?
Hello all. I need your help in convincing some of my customers that they have a less than optimum RO delivery system. What pressure do most of you use to deliver this? I keep running across a lot of places that use a basic irrigation pump, with a bladder tank setup. When new something like this will deliver water at around 50 psi. I like to use a booster pump that puts it out at a little over 200 psi. I think a lot of distributors use these cheap pumps because they are cheap and simply don't know any better. So that I don't come across as simply trying to sell these people something they don't need, I thought it a good idea if we could see what the norm is.
We are using 200 PSI & it seems optimal. 50 PSi seems too low. You did not mention GPM which could be a factor. We use a Procon stainless steel pump to repressurize.
WashGal
Ours comes out at a higher pressure than most, about 350-400 psi. We have found that customer like this better. It feels like there getting something, but its not too much that they can use it instead of high pressure rinse. I think that water usage is about 2 gpm at this pressure
Wash-A-Roo
Living off .25$
Weatherford,Texas
At one location it comes out at 200 psi and at another we have it at 500 psi coming out of the hp. pump. People love it that high. I also agree that you don't want to go to high cause people would use it for hp rinse. I think alot of this should be based off of what you can produce in your ro unit.
We're also running medium (450 psi) pressure with a Cat 390 pump and large orifice solenoids. There are a few customers who use it instead of rinsing, but it's infrequent and easy to convince them that it's cheaper to go around once with high-pressure rinse before spot-free. At least 80% end the cycle on spot free rinse.
Thanks for your replies. That is pretty much what I thought, but it's nice to see it verified. I still run across a lot of places in Florida where it comes out like a three year old at the toilet.
cebo
In my case my distributor used a shallow well jet pump on a precharged bladder tank that only put out 40-60 psi. I think the main reason was it was easier to install and charged about as much as a booster pump. I changed it to 350 psi and use of SFR went through the roof. With my old system almost no one used it.
wash4me
Kansas City
I realize this is old but what kind of tubing to you use for this pressure? My tubing is 3/8 od white unmarked tubing that runs out to each bay. We currently have 125 psi and I am wanting more.
It's a Parker 3/8" OD nylon tubing rated for 750 PSI working pressure. I found something a lot cheaper but I don't remember where.
