Spot Free Rinse Pumps
You need to find out how much output your IBA requires so you can size the pump correctly. I have had good luck with procon and rotary style pumps on SFR. They seem to last forever.
It depends on the gallons needed. Mine IBA call for 11 to 20 gallons per minute.
copperglobe
If using a Sta-Rite or Procon pump is your spot free water stored in a tank above ground or below ground level? If your tank is below ground does a good foot valve work to keep up the prime on the pumps?
