Spot Free Rinse System
fastlx
Georgia
Hey guys. Just wondering if anyone has a manual for this unit. I have tried WASHWORLD and they don't have one. Also where I can get the membranes.
Thanks again for all your help,
Vic
cooll903
Illinois
i got my membrane from amazon. just pulled out mine to look at the part number so i made sure to order the right one. as for a manual i cant help there. sorry
When replacing the membrane be VERY careful to place the cup seal on the membrane in the same place as the old one. It will want to go one way only.
The V seal on the membrane is to keep the flow from going around the membrane. If you happen to pull it out and don't notice which way it was oriented, it goes on the end that the pressure from the pump comes in.
call Stan at Con-Serve in Lakeland Fl
I believe there membranes will work with your system.
It's a standard 4x40" membrane, any of those will fit, but more info is needed to get the correct one. Kleen-Rite is almost certainly going to be cheaper than an equipment manufacturer.
