surgical tubing for shampoo vac
Eric H
I need to replace the surgical tubing in one the perisaltic pumps in a Fragmatics shampoo machine. Can anyone tell me the correct ID and OD that I need to get? I can't tell if the origional stuff is swollen. Is there some type of supply house for some other industry that I can find this locally?
I'm having a similar issue with a D & S fragrance/vac. I have one fragrance line either plugged or broken. D & S wants about $300 for a new hose assembly because they don't sell the tiny little tubing and I can't find it anywhere.
I went to the above mentioned website. Looks like they probably have what I need. Thanks!
Eric H, you'll probably find that most places will only sell a minimum of 100 feet of the tubing. You can order it directly from Fragramatics. It shouldn't swell if you use their shampoo/spot/removers.
washme1, you're talking about 1/8" OD nylon tubing. You can get it from Grainger or a Parker distributor.
I stopped at the parker store to see if they could help. They don't stock it but, they did have some left over from a sling shot they made. They cut me off 5' for free. The boss had made them take the sling shot apart:(
The tubing in my machine is very, very small ID. I tried running some picture hanging wire thru the tube, it was slightly larger than the wire. I think I'll call Eldon James to see if I can send them a small piece. Thanks
