Switching from gs400 to dixmor 6 need help
Ronnie
Hello,
Switching from gs 400 to dixmor 6
just picked up a car wash that is extremely outdated.
so I am switching from gs400 to dixmor6
I need help with wiring the dix6
The current gs400 is using
Yellow wire
Purple wire
Solid red
Red green.
Can anyone please tell me which dixmor6 wires match with the current setup?
thank you!
Roz
we did the same change with our bay meter boxes and vacs. Dan Kamsickas (tech support) at Ginsan was most helpful with info to assist us in the conversion. 1 (800) 446-7267;608
The vacs were GS401 timers so no display. They required a step down from 120V to 24V
The meter boxes I believe were the same voltage since they were GS400 displays. We upgraded the entire doors so ginsan sent us the door with the Dixmor already installed such that we just needed to attach a ribbon connector. Call Dan as he usually can get to the heart of the issue quickly.
edredtop
California
Hello,
Yellow wire
Purple wire
Solid red
Red green.
thank you!
Full data sheet 👉 here
Wiring diagram here 👇
Jsshac
Hello,
Yellow wire
Purple wire
Solid red
Red green.
thank you!
Hello,
Yellow wire
Purple wire
Solid red
Red green.
yellow # 6
Purple # 9
Red # 10
Red green # 2
thank you!
