Switching to Simoniz
briteauto
I'll be switching my chemicals over to Simoniz and will be purchasing through KR - no distributor. Have spoken to some other operators, visited locations, as well as KR people and Simoniz directly.
Simoniz has an extensive line and I was wondering what specific products some other Simoniz operators on this forum are using for:
IBA friction:
Detergent
Sealer/DA
IBA Touchless:
Presoak - one or two step
Sealer/DA
Also - on the sealer, anyone use Dri Brite? A combo sealer/DA.
I've seen the Poly Sealant and am not sure if this supplies enough break to dry or if it is more a sealer that also needs a separate DA.
Am also incorporating the new carnauba wax product they have put out.
Thanks in advance for sharing any info.
Mike
“I'll be switching my chemicals over to Simoniz, no distributor.”
“Simoniz has an extensive line and I was wondering what specific products some other Simoniz operators on this forum are using for:”
Mike,
Good move on ingredient co-branding.
I once worked for the chain so branded - good products and name recognition.
However, with the season coming up, I would not recommend “no distributor” approach.
Most of my clients ingredient co-brand. Each used a process to create awareness and image.
This included getting a competent technician on-site to help formulate the service recipes, select, set-up and calibrate the chemistry and brand the point-of-sale.
If you have a website, there is also plenty of marketing material you can embed.
