Swivel Questions
My touch free has a large 2 piece swivel on top of inverted L spray bar.
This swivel accepts hi pressure line and spot free line.
The inner piece is stainless and has 2 o-ringed ports at bottom.
The swivel leaks out the top under low pressure soap passes (not where it attaches at bottom by o rings).
Is this an indication that the outer brass is worn? inner ss piece of swivel is worn?
pgrzes
S.E. Pa.
I tried to rebuild mine before to no avail.!!! They began leaking very soon after rebuild. I have tried single row and dbl. row bearing swivels. The Dbl. Row super swivel has been best one.
