Reds
I have a Rinnai tankless heater on order. I am going to hook it up so that it circulates the resevoir water in my JCC self serve. I am only feeding 2 bays, and water for the soap & hp wax are all that get drawn out of that tank. I will be hooking up a circulator pump controlled by an line voltage aquastat, which is fed power from a timer. That way I can turn off the heater during the dead of night and it will only run when the aquastat calls for it. The only reasonable place I can mount the heater is about 15 feet from the SS resevoir and there are a lot of obstacles in the way (heater vents, plumbing lines, water service, etc). Has anyone ever used rubber hose (push lock?) for the feed lines to and from a tankless heater? Or must it be copper? The push lock hose is rated to 150?. PSI doesn't matter because it is an open system that simply circulates water thru the heater and resevoir. Hose would be a much simpler installation. Thanks in advance for any input
