Temp probes
pgrzes
Ok so I want to add temp probes for my Washworld HV. I call to find out what all is in store to add this. Holy COW $250 each for the temp probes plus the Wiring kit for them. Just wondering if there are any other options for these probes? I believe it is just a 24v 3 wire probe?? Anyone have another option??
What do you want to add the probes for? The probes are so so expensive, because they are digital, and the Washworld is programmed to accept the input from these particular probes. If you are wanting them to simply activate your weep, then use whatever you are using for your SS bays...... You will not be able to monitor bay temps through the washview remote, but the bay will weep with the use of your weepmizer, or whatever other system you choose.
