Eric H
Just a tip for the new guys here. It was 40 degrees this morning when I got to the wash, which reminded me that I better check the weep system before I find out it is not working.
Be sure to take out and clean the strainer if you have a Watts U5B pressure regulator. Close and open the needle valves that conrtol the weep rate, junk likes to build-up there and cause flow problems.
I usually look for 10-12 oz per minute from the gun and much less from the brushes.
good luck
good luck
