I have a smaller tunnel that I took over a while back. The equipment order is as follows:
All Belanger - Four basket front to rear mitter, low side washers, high side washers.
The tri foam application is set up after the high side washers, and stays on the car a few feet, and is then rinsed off. Is there a benefit to having the tri foam worked in with the friction? I know it may help with rinsing, but that is not a problem - I am getting a good rinse. I guess I am asking if the foam is more effective (by effective, I mean in lowering the ph to help with drying) if it is worked in? Obviously, in a touch free, it is just rinsed off. Are some types of foam better than others if they are not worked in with friction? I use Lustra products.
If I change the position of the tri foam to before the mitter, then I am applying it before the car is washed, and I am already using an alkaline solution at this point on the vehicles. I use a low ph tri foam to help with drying and would prefer not to apply it too early in the tunnel.
What are your thoughts?
