Tri Gloss Stained White Trim
washme1
Didn't realize the tip in the injector for my red tri gloss had broken causing way too much product to be applied. Customer says the red tri gloss stained his white trim on the side of his vehicle. He is bringing it in tomorrow for me to look at. Is there any way to remove the stain from his trim or will I need to have a body shop replace it?
A decent heavy duty cleaner should remove it. If it is painted it might have to be buffed. Should probably apply a wax after you remove it.
Let it set in the sun.....It will be gone in no time...
Mr. Aap is right. I once had a car get stained and my chemical supplier told me the sun would make it fade. That's exactly what happened. The customer was willing to give it time, he was satisfied, I was happy and the supplier was relieved.
