In my tunnel, they have two distinct functions, benefits and style of application. If you are asking what would be better in a self serve foam gun, I’d say hot wax because it generally is a foamier product and that is what you need in a foam gun.
Yes, I am. I am using Quest Vantagloss at two washes and will use at a third when I go through my Carnuba products. It works very well. Vantagloss only comes in one color so I have to inject color with a dual tip eductor.
Greg, how does it foam? In your opinion does it perform better than wax? Would ceramic still be effective if it was dispensed at low pressure out of the hp gun?
Quest makes two versions. I use lower foam in IBAs (easier to rinse)and foamy in the SS, The foamy works well. I'm not a fan of low pressure wax coming out of a HP gun nozzle but I guess it would be considered effective.
Has anyone dispensed two different wax products out of a low pressure gun? If the changeover time is not different that would be an optimal way to apply a Rain-X product. The "ceramics" as I understand are more about gloss and slick feel, and the repellent products are more about protection.
You guys are wasting too many brain cells analyzing this stuff. The customer will only know or care if it beads/sheets water. It's all just wax to them.
