Washworld Razor Touchless. Triple foam lines are running out of color after each wash. So when the next car gets washed they are only seeing bubbly water up until halfway on the vehicle, then it comes out in full color and foam. I replaced the check valves at the furthest point in the system right before it goes into the foaming thing and onto the vehicle. Inside at the pump station you can see the difference in color from the bay that is working and the one that isn't. After a little while the lines go from bright colors to faded.
I thought having a check valve would stop anything from flowing but you can see the color draining onto the bay floor after the wash. Could this be a bad solenoid? Any other ideas for troubleshooting?
