Triple foam pods on laser 4000 wintertime
tdlconceptsllc
Yesterday it got cold here in NC and we switched the triple foam to come out the spray arm instead of the pods. how can you still use the pods in winter what kind of kit part numbers ect..or it's just not worth it.Thanks again guys. Laser 4000
Your chemical distributor should be able to provide you with a methonal based tri foam that will not freeze. No additional components are needed.
