Dogwasher, at one wash I owned we had three Rinnai heaters piped in parallel with two 99gal gas fired water heaters,, at this wash this setup heated water for three water wizards, using hot water rinse, chemical mixing, rail and gantry heat, and floor heat for three bays and entrance aprons and exit aprons. we used a heat exchanger for the glycol in the floor heat. It worked well
The summer you could turn off the 99gal water heaters and just use the rinnai and cut the temp back and save a lot of gas.... Just a thought for you if you think it will be right for you.
