Tunnel heater recomendations
gearhead
What do you tunnel guys consider to be the best option(s) for heaters? Brands /Types. Thanks!
Tyoicaly use 300k BTU ceiling hung gas forced air. One at each end. Some Reznor. I will check what other brands.
I am Guessing you mean 300,000 BTU and Not 300. I am in Chicago and have places with 2 of these 300,000 BTU heaters and they do the trick until about -10 degrees depending on wind (Not wind chill)
gearhead
Thank you Earl! I did mean 300K.
Just trying to make sure I have enough punch for the winter. With the narrow bay it will be difficult if not impossible to place a torpedo heater anywhere if addition heat is needed. May have to hang one or build a some sort of shelf.
