SSadmiral
Young buck
So I cranked up the psi to about 800 ish to help clean the really dirty cars. and all was fine for several months until I got a call on a Honda pilot customer said my wash damaged her car. Turns out just the door molding that runs parallel to ground was damaged which appeared to be from the nozzles based on the pattern of damage. It looks as if the water pushed in/ over the plastic! I'm assuming that the plastic they used was inferior or was after market, either way I'm going back to 600 ish.
