Undercarriage Nozzles
Eric H
I recently had someone comment that the Sideblaser Nozzles on my Razor are not as powerful as they were when we opened a year ago. I have 6 Hydra-Flex nozzles on each bay. How long should they last? and can they be rebuilt? Should I try a different brand? I see others available, some more expensive some less expensive.
Hi Eric, longevity depends on the usage and the quality of the water going through them (hardness, chemicals, reclaim etc.). Yes they can be rebuilt as there are rebuild kits for them. I like the Hydra flex because they can be in any position when they are activated. Many brands of rotating nozzles require that they be pointing downward when activated because they have ceramic components that will shatter if they slam up against the housing when horizontal or pointing upward. So whatever you choose to replace them with, be certain that they can operate in any position.
