I started adding night lights to some of my vacuums that only turn at night when a vacuum is paid for. I wired a LED light into the vac motor power supply so that it turns on when the motor is running. It only draws 23 watts but puts out 1400 lumens of light. The power draw is minimal so no need to worry about excessive draw on the power supply. This first one is mounted on the dome but others may get mounted on a light pole. I used a heavy duty extension cord that I cut in half. It is wired so that if i need to take the dome off all I do is unplug the extension cord connection. Total cost was under $75. I always wondered why vacuum MFG. never offered something like this built into the vacuums.
