Vending and Rear Load change install
nandromidas
New here and looking forward to learning from all of you. Does anyone have referrals in the DFW area for someone that can cut into brick wall and install a new vending and rear loader?
I did this a few years ago. I hired a concrete cutting company to cut a hole in the block wall. They did a fine job but concrete dust got everywhere, and I mean everywhere.
I recommend taping off the area with plastic sheeting.
Perfect great appreciate the heads up.
Where are located in DFW? I am in Ft Worth and have some contacts.
It's not that hard to do, rent a saw, measure four times and cut once. A wet saw will stop the dust but spray water everywhere.
That angle on the edge of the door is a really good idea. Someone tried to cut my deadbolts, but they didn't get even halfway through. That angle would have stopped them cold. One of the washes I look after was broken into by a stupid kid with a pair of diagonal cutters. He spent 90 minutes hacking at the door to get in. That angle would have made it five times harder for him to get in.
The last couple of changers I’ve installed that I had to cut the wall I used a gas powered concrete saw with a water cooled blade that I rented. The water made a bit of a mess but there wasn’t a lot of dust like there was when I didn’t use the saw with the water cooled blade. I always cut the hole an inch wider and taller than what the cabinet is, so there’s a ½” gap all around the changer then fill the gap on the top and sides with expanding foam in a can. The foam is like gluing the changer into the wall. Then put some steel angle iron on the sides and you’re done.
