Wall Cleaner
Mansfield ohio
Ive tried klean wall with no luck really
and a few others even tried dollar store toilet kleener that works just as well as any
the magic spray on spray off is aluminate
this stuff will clean anything
works great on the vynly walls and all the stainless cleans up like new
no scrubbing
pgrzes
S.E. Pa.
Ive tried many different cleaners and agree with Randy. Nu-wall from Arcadian is a true spray on spray off.
I buy low fume Muratic acid at Home depot for around $7. 1 gallon diluted 2 or 3 to 1 will let me clean a large IBA in less than a hour. 1 gallon will clean a couple of SS bays.
TEEBOX
Detroit, MI
no scrubbing
hi, you get this stuff from a dollar store? What's it called?
tdlconceptsllc
NC
Arcadian also has a HF free version called NU-wall 2. I don’t know how it cleans vs the original formula for people that want one without HF
br549ms
Mississippi
The NU-Wall 2 works good on film and organics and works great on equipment.
The best thing I have found for cleaning the wall is my wife, bucket of soap and long handle brushes (don't tell her).
tdlconceptsllc
NC
Straight no water in pump up sprayer wet the surface with water before and rinse within 2-4mins
Car_Wash_Guy
out west
For those using Klean Wall do you use it straight or dilute it?
I've applied it straight and removed with a pressure washer at 4500psi @ 4.5gpm. Comes right off
I've also diluted it 50/50 and applied with sprayer and then hit with a wide brush.
Both about equal in regards of time and chemical consumed.
I mix it with about 2 parts water. I stopped using a garden sprayer, I dip an old foam brush head and mop it on the wall. About half of it gets wasted with the sprayer.
Mansfield ohio
Aluminate just went thru this with my chemical guy
he said use his so i showed him how quik it came clean with aluminate
spray on spray off will shine anything in seconds specially the stainless
nu wall and all the others u have to scrub or keep re appling
dollar store buy the works for toilets and it will clean a boat hull and panels pretty good will have to scrub a bit
kleen wall plan on scrubbing
DiamondWash
Des Moines, Iowa
Has anybody here used KC Chemicals Wall Cleaner?, I see it advertised in PC&D it's called NHF Wall Cleaner.
