WashWorld error codes?
TechGuy
I'm getting a Code 60 on my High Velocity. Every manual I have only shows codes up to 56. What is code 60? Thanks!!
60 is arch rotate failure IIRC. As for which prox switch it is specifically, I couldn't tell you off the top of my head, I'll look at my cheat sheet tomorrow and let you know if nobody has answered you first. Also 39 I know off the top of my head means that the wash has been out of service for at least 15 minutes. 28 I don't know off the top of my head, I'll look on my cheat sheet for that tomorrow too.
Number 60 is prox number 5 is on when it should be off.
number 39 is wash out of service for 15 minutes.
Number 28 is main tank over fill. ( no input from fill sensor )
Thank you!! I thought that the problem was 5 was off when it should be on... (e.g. bad connection somewhere)... You just changed my whole thought process now. Any chance you can scan/upload your list? I guess I can just call WashWorld tomorrow and see if they can email me an updated manual. Thanks for your help!
List of prox codes and quick explanation
60 Prox 5 turned on (should be off)
61 Prox 5 turned off (should be on)
62 Prox 6 turned on (should be off)
63 Prox 6 turned off (should be on)
64 Prox 7 turned on (should be off)
65 Prox 7 turned off (should be on
