Water Softener replacemetn input????
We have 2 two 65" high 16" diameter with 2 brine tanks Ecowater water softener system. They were in 1987 the more efficient gallon count-microprocessor style. 1-1/2" is their piping manifold size. One of the twin softener's has developed a leak in the middle of its now obsolete fiberglass head. We took the head off to a fiberglass repair shop. Ater a 24 hour cure time the patch allows tiny seepage!!! Anybody successful doing that?
It looks like since the system is 21 years old we will be looking for a new system. Any suggestions on the current brands & options---- softener wise. I am very conscious of water pressure drop through these softeners so I would like to improve on that. Hopefully, there can be salt & water efficiency gains. I don't know how though --- unless they have improved the gallon count technique.
I've always had great luck with Fleck heads.
Pressure drop is usually more of a concern because of the vessels than from the head, unless that is undersized.
PaulLovesJamie
rural 5 bay SS
Kutztown PA
I wouldnt replace it an entire softener just because a fiberglass tank had a leak, I'd replace the fiberglass tank.
FYI, I've dealt with softenerparts.zoovy.com before, I got good service.
He said the fiberglass head is leaking...
tobaccofarmer
Have you considered switching over to nano technology? No salt just a media that the water passes through! Several different kinds and several different ways to set it up, however go to www.aquascience.net and check it out!
Central Texas
I Changed One Cw To Soo Soft Electronics. Did Not Beleive It Could Work!!!!!!!!!!! But The Cars Are Coming Just As Clean......... Already Had Spent 3200.00 On A New Head That Was Only 3 Years Old!!!!! No Salt, No Softner!!
jimbeaux
Water softener
Cleaning up mud, just wondering if the "electronic" water softener substitute is still working. Any spotting problems or suprises that you have found?
Thanks for any info you or anyone else has. Looks like I need to replace my 14 year old softener. Every time we fix one problem something else seems to come up.
Ric
Cantree Member
West Michigan
Tell us more...are you feeding this water into an ro unit? Did you have a conventional softener before this? If so...did you need to make any changes to your chemical mixtures? How many grains of hardness is your incoming water?
I'm sorry for all the questions but inquiry minds want to know;) This technology has always intrigued me but I've been skeptical and wanted someone else to be first...you;)
