Water Softner's
Central Texas
If you have re beded your softner yourself, I want to know if you used sand or gravel at the bottom before you put in resin! Thanks:eek:
Ghetto Wash
Gravel. Went to Home Depot and purchased some that was about the size that I dumped out.
You use gravel. Smaller softeners use one size (usually #20) flint, larger ones may have a coarse layer with a finer layer. Sand would restrict water flow.
