Water Wizard 1.0 blow down
washnvac
Seaford, DE
I have a WW 1.0 that parks at the exit, and dryers are free standing right after the machine. When the wash finishes, there is a blow down cycle before the car ever leaves the treadle. If the vehicle exits really fast, they get a bit of soap on the vehicle that the blowers do not always remove.
Does anyone know if there is a way to delay this. I assume this is the standard start of blow down cycle when outside temp is below 32. But it sure should not start before a vehicle has exited.
Any thoughts or suggestions would be appreciated. Thanks.
I have never seen any blowdown adjustment settings on the WW. Mine always waits about five minutes.
Wizards with onboard dryers do a quick purge, but not a full blowdown. My wizards with freestanding dryers do not purge. I'm wondering if there is a setup issue. Also, is it possible that you are doing something with your dryer outputs (like hitting the reset circuit) that would cause this? Just some thoughts....
washnvac
Seaford, DE
I only thing I noticed on the set up with the dryers, was a 2.5 second delay for starting. I did set that to zero yesterday. But I have not talked to my attendant to see if it made any difference. And like you, I have not seen any set ups for the blow down. I figure if anybody knew how, they would be here on the forum.
