Water Wizard 2.0 CAT Pump belt size
Alsoar
The CAT pump on my Water Wizard 2.0 is sounding a bit odd so i'm guessing the belt might be getting old. Now i'm thinking i should buy a spare belt just in case.
So, I tried searching the forums and Google for the belt size first but haven't had any luck.
Does anyone happen to know what's the belt size for the Water Wizard 2.0 CAT pump?
Thank you
Somewhere on the outer jacket of the belt here will be a number. This is the type belt it is, I’ve never seen a belt that didn’t have a number stamped on it. My self-serve pumps belts have a B-52 stamped in them and my air compressor has a A-27 stamped into that belt.
