Hi all. We recently fitted hydraflex turbo nozzles to our fleet of water wizard 2.0's. The difference is awesome. I am just wondering though as to what operating pressure others are operating at. Im at 900 p.s.i but would like to crank it up a bit.
I thought the whole point of those 0° spinner nozzles are to save on water? Can you tell a difference? In theory you could get a smaller cat pump to replace that cat3535.
I would agree with the smaller cat pump. It would surely reduce the equipment price. Also, as their is a wide spray pattern you could probably have less nozzles. So even less water. Reds are you using turbo nozzles at 1200 psi?
I use whichever kit had the largest nozzles. I believe the larger nozzles clean better but use more water. They still use 40% less water than the normal zero degree nozzles.
I am also converting some water wizard 1.0's to the hydroflex nozzles. I was told by the manufacturer that the pressure cannot exceed 1000 psi on any nozzle at any point, thus you have to set your regulator to 1000 psi when just the top boom is spraying since that is the fewest amount of nozzles in use at any given time.
