weep-mizer seems to back-feed into wash, rinse and wax tanks on manual bays pump stand causing them to overfill and drain from overflow. My question: could a check valve be added after the point where the three solenoids converge. Does the "Cat" pump produce enough suction to overcome a check valve ? Apparently these solenoids don't prevent a reverse flow. I'm sure the spot-free pump is probably back-feeding too, just not a noticeable because it isn't on as long. Thanks for any suggestions.
