weight of shurvend and security cage?
i want to move my vending machine to the front of my building. what is the weight of the unit including security cage?
thanks!
Uncle Sam
California
thanks!
The vendor and cage will weigh about 1250 pounds. If you have a smooth surface, a pallet jack will work well to move it.
Uncle Sam
I've moved heavier stuff than that with furniture dollies. It should be easier than a pallet jack since you won't have to lift the entire unit at once to get under it.
Thank you
I think my parking lot is a bit too rough to use a pallet jack or dollies. I was planning to use a tractor with forks.
Uncle Sam
California
Just be careful as you do this because these machines are very top-heavy and tip easily. Strap the vendor to the forks for safety.
Uncle Sam
